Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Join Date
    Dec 2008
    Location
    Asheville NC
    Posts
    250
    Points
    3,093
    Level
    34
    Default
    Yep, I checked the back of the citronella jug and it says 'carcinogen'.. Gee, glad I asked.....
  2. # ADS
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #12
    Join Date
    Dec 2008
    Location
    Houston
    Posts
    143
    Points
    2,243
    Level
    28
    Default
    Kerosene? I remember when you could buy that at gas stations when I was a kid, but I'll bet I haven't seen it in 40 years.
  4. #13
    Join Date
    Dec 2008
    Location
    Upstate SC
    Posts
    661
    Points
    4,231
    Level
    41
    Default
    Quote Originally Posted by RossA View Post
    Really? I saw it where I bought diesel today. Real common in this area.
  5. #14
    Join Date
    Feb 2009
    Location
    Gatesville tx
    Posts
    39
    Points
    2,184
    Level
    28
    Default
    I've used charcoal lighter in a pinch (after Hurricane Rita)--keep the flame low. Yes there is some smell.
  6. #15
    Join Date
    Dec 2008
    Location
    Houston
    Posts
    143
    Points
    2,243
    Level
    28
    Default
    How close is kerosene to Coleman fuel? Could you operate a Coleman lantern or camp stove on Kerosene? We cooked a lot of meals on our Coleman stove after Hurricane Ike. If so, it might be good to have a 5 gallon can (or several) on hand.
    Also, in a bind, is it possible to use kerosene in a gasoline generator, either straight or mixed with gasoline in order to stretch your supply of gas?
    Or will this result in one of Rusty's "explosive moments"?
    Note to self: figure out where to buy kerosene down here nowadays.
  7. #16
    Join Date
    Dec 2008
    Location
    Houston
    Posts
    143
    Points
    2,243
    Level
    28
    Default
    OK, I checked with Home Depot since they sell kerosene space heaters. They sell Kerosene for over 10 bucks a gallon!
    There has to be someplace that sells it cheaper than this.
    We just don't use this stuff much down here.
  8. #17
    Join Date
    Jan 2009
    Location
    North West Louisiana
    Posts
    316
    Points
    4,508
    Level
    42
    Default Wick Preparation Really Helps
    Quote Originally Posted by Loshali View Post
    I've purchased a couple new oil lamps and plan on using them now, not just 'in case'. I'm trying to stock up on fuel oil. I bought a couple gallons of citronella, thinking I could mix it with the other fuel oil since it was cheap and does have a nice scent. But the 'ultra pure' kerosene lamp oil at Tractor Supply was $4.99/quart on clearance!! Thats $20/gallon, on clearance!! Is ultra pure really necessary? I'm going to experiment with baby oil, mineral oil, etc. Man, it ainta gonna be cheap to light by lamp light....
    Lo~
    Ultra Pure is really not necessary. If you first trim the fuzz from the top of the wick, and make some small 45 degree cuts to the corners of the wick, it really eliminates smoke. Additionally it helps produce a wider, brighter and controllable flame pattern that you don't have to constantly adjust. Make sure you have given the wick time to soak up the lamp oil before lighting it. I personally like and use lamps with wider heavier oil reservoirs at the base; not as easy to tip as some of the fancier taller ones with reservoirs dangerously too high. Please keep a quality ABC type fire extinguisher nearby and read up on how to use them properly for maximum effectiveness. Also make sure the batteries are changed on all smoke detectors twice a year. I change mine out during Daylight Savings. Good Luck.
  9. #18
    Join Date
    May 2012
    Location
    Virginia
    Posts
    1,557
    Points
    7,871
    Level
    59
    Default
    You can also use olive oil in some lamps, Leman's store has the proper jars for this also. you can check out there site for what you need and I havn't looked yet, but you might be able to get the proper jars cheaper, but it will show you what you need
    applejack
  10. #19
    Join Date
    Apr 2012
    Location
    South East PA
    Posts
    120
    Points
    1,680
    Level
    23
    Default
    coleman fuel and Kero are to different things. Some of the coleman products are duel fuel Colemanfuel or Gasoline only. I get all my Kero from the pump.
  11. #20
    Join Date
    Apr 2012
    Location
    South East PA
    Posts
    120
    Points
    1,680
    Level
    23
    Default
    I have a bunch of oil lamps and also The Alladin Mantle Lamps there equal to a 60 watt bulb. They burn so clean on Kero you dont even smell them. All my kero comes from the pump at the gas station
    Attached Images Attached Images
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
